I just finished installing a 430W in my RV8's panel. I also have a 496. Both antennas are mounted under the cowl. The 496 antenna is mounted on a shelf on the firewall and the 430's antenna is mounted on a shelf attached to the engine mount. I ran the cables together in a bundle that passes thru the baggage compartment tucked into the u-channnel that the baggage door hinge attaches to. The problem I'm seeing is that as soon as the 430W is powered up, the 496 loses all satelite reception. If I separate the antenna cables the 496 begins to see satelites again. It's hard to believe there is crosstalk but it appears there is. Has anyone else seen this?
Chris
Chris
