David Paule
I tried out four rivet guns and half a dozen flush rivet sets while I was recovering from scrapping my horizontal stabilizer.
Here are the rivet guns. We'll number them 1 to 4, left to right. I'm using a Harbor Freight air pressure regulator and the psi that I mention is static. When there's heavy use, the pressure drops. I don't use a flow restrictor at the guns.
Gun #1 is covered with Pro-Seal from riveting and Pro-Sealing the center wing assembly of a production airplane, as we turned it into a wet wing aircraft. I don't know who made the gun, but I bought it around 1986. It's a 3X and is nicely balanced. It has a decent but not exceptional trigger. Setting AN426AD3-3.5 rivets, it's happy on about 15 psi. Unfortunately I used 30 when I over-set the rivets on the skin of the horizontal stabilizer.
Gun #2 was borrowed from a friend. It's not balanced as well as gun #1, but otherwise performs about the same. I used it to set a few of those rivets at 30 psi, and that was too much. It gave much the same results on the stabilizer as gun #1. It's made by ATS and set the large rivets in the 46 foot long wings of a Xenos motorglider. It's a 3X and he would have been better off with a bigger gun for that.
Gun #3 was borrowed from another friend. It was used to build an RV-8. It's a 2X and handles nicely. It's relatively light. I don't know who made it, but there's one that looks like it in the current Aircraft Spruce catalog.
Gun #4 is a brand new Sioux 3X gun. It's got a very nice trigger and surprisingly poor ergonomics for that much money. It seems to prefer about 20 psi, maybe a small bit lower than that. 15 psi is clearly too light.
Here are the rivet sets. We'll put letters on them, "a" through "f," left to right.
Flush set "a" has a small head. I used this one to drive all the skin rivets on the stabilizer. The small size, combined with the high pressure I used, put a concavity on the skin along the lines of rivets, and that led to me scrapping it. Brown Tools calls something akin to this one a "suicide" set. They didn't sell this to me. I borrowed it. 'Nuf said.
Flush set "b" is from Cleaveland and I bought it earlier this year. It only works in the Sioux gun. It simply won't set an AN426AD3-3.5 rivet in any of the other guns. It doesn't matter the pressure.
Sets "c" and "d" appear to be identical. One is from Avery and the other is from Brown, both recently. They work nicely in guns #1, #2 and #4, the Sioux gun. They don't work at all in gun #3.
Set "e" is an old guarded flush set I bought somewhere back in 1986. The guard is off it for this test. Compared to the others, it's got a fairly flat face and smoothly rounded edges. The guard is just a grommet. The set only works in gun #4, the Sioux, and it's sweet there. Very nice.
Swivel set "f" is on loan from the RV-8 builder. It's good in all the guns except the Sioux. It'll work with that gun but for some reason it seems to need a third hand on that gun. Due to that awkwardness, I'll be giving it back shortly. It might have come from Aircraft Spruce but I'm not sure.
Bottom line is that the Sioux gun is acceptable once you get used to it. It'll fit a hand that's smaller than mine. I wear size large gloves and the gun's handle is small for me. It's a little heavier, with slightly worse balance than some of the others, but its nice trigger and its ability to accept a wide range of rivet sets make up for that.
I'll use the flush set "e" without its guard if I can, and one of the ones from Avery, Brown or Cleaveland otherwise.
Thanks to Dave Dooley, Jim Sherry, Rod Woodard and Bill Hug for help, the loan of tools, and advice.
Dave
![dwdgkm.jpg](/proxy.php?image=http%3A%2F%2Fi46.tinypic.com%2Fdwdgkm.jpg&hash=88f834d88939feaa10e6c6e4e7c94f8c)
![16275fb.jpg](/proxy.php?image=http%3A%2F%2Fi48.tinypic.com%2F16275fb.jpg&hash=637ae9584012a22c119beb65bc7ef720)
Dave
