3M PPS Tip
AlinNS
Hi Folks.
For those of you that use the 3M PPS system, I have a tip that I hope hasn't already been covered:
If you suspect you may have missed a couple of small spots here and there, or need to fix a few dings. Take a close look at the left over "bag" from your recent spray session - my gun leaves a tiny amount behind. If it's been capped with one of those included caps and hasn't had enough time to cure you may find just what you need is available to be squeezed out. Turn the cap over and it makes a great little container for a q-tip or small brush... sure beats mixing a tiny amount... also I'm too cheap to toss it if I can still use it.
[/URL][/IMG]
