32-04, chafing of tubes vs flap handle
Mike Buettgenbach
Active Member
Sponsor
I've just installed the flap handle and associated hardware. Even with careful installation and prior measurement, the end result is that the flap handle assembly chafes against the brake lines and wire harness. The amount of "rub" is small, i.e. not much surface area against the brake lines, but still its rubbing. Any practical way to "fix" the rubbing?
Thx!
i tie-wrapped everything about every two/three inches to keep it tight...some have run a thick tie wrap over the top and tied it off with a "head" on the other side. Lots of tight stuff in this little bird. Wait till you get to the engine/cowling etc! But in the end it all works out wonderfully and flies great.
