I called Vans today when I was unable to locate the ES 9 Pin Backshell 2 in my finish kit. The ES 9 Pin Backshell 2 required for step 3 is not included in the finish kit. So no need to search for the missing part, the backshell is part of the Avionics kit.
The backshell to that DB-9 is special because of the screws - the "Backshell 2" as listed by Vans. Remember, the backshell is not the plug! The backshell 2 has shorter screws that require a screwdriver (shorter than all of those thumbscrew-type backshells behind the panel) that do not interfere with the magnetometer that is part of the ADAHRS unit. (But they are NOT "non-magnetic" screws.)
