3/4" Tube Bender
CharlieWaffles
Anyone in the area have the ability to do a very simple radius bend in some 3/4" Aluminum tube? I got one of the spring bender styles and it didn't work out well. All of the hardware store tools only accommodate up to 5/8"
Alternative quick method is to sandwich a circle of plywood between a couple of sheets of plywood and bend to whatever radius you want (within reason) by making the circle the right diameter/radius. Two outer sheets of plywood help keep the tubing from collapsing. Works pretty well for fairly soft metal tubing (aluminum, soft copper).
Greg
