2024 Solar Eclipse Viewing
From the American Astronomical Society:
"Are Welding Filters Safe for Solar Viewing?
The ISO 12312-2 standard was based, in part, on decades of experience using welding filters for observing the Sun. A welding filter with a shade number of 12 or higher transmits a safely tiny percentage of the Sun's light across the spectrum, whether made of tempered glass or metal-coated polycarbonate. Most observers find the view through a shade 12 welding filter uncomfortably bright and the view through a shade 15 or higher-numbered welding filter unattractively dark. The "sweet spot" is shade 13 or 14, which best matches the view in purpose-made eclipse glasses and handheld solar viewers, except that the image is green rather than yellow-orange or white. Shade 13 and 14 welding filters are rarely stocked in welders' supply stores, though, so you'll probably have better luck finding them by shopping online. Two good sources of shade 14 welding filters are safesolarviewing.com and Phillips Safety Products.
You should not use adjustable and/or auto-darkening welding helmets or similar products to view the Sun. Many don't go as dark as shade 13 or 14, and even those that do post a grave risk to your eyesight, either because you accidentally adjust them to an unsafe setting or because they don't auto-darken fast enough when you look at the Sun with them."
The Texan who probably flew 135 is probably a good man.... I offer the benefit of the doubt. Hope it doesn't rain on your eclipse.
ECLIPSE!, Noon until Gone. Oswego County Airport [KFZY], Fulton, NY.
To help celebrate the Great Eclipse of 2024, EAA Chapter 486 will be
serving hamburgers ($3) and hot dogs ($2) along with coffee, soda and water
at their hangar on the airport's northside.
Note the eclipse starts at 2:08 p.m. with totality beginning at 3:21 p.m. and
lasting for 3 minutes and 10 seconds. Be sure to use proper eye protection and
check NOTAMs before flying in!
for two bucks, you get eclipse glasses at just about any store. for a dollar more, you can get a mirror... and solve that mystery you just posed....
I have enough glasses to give away for free just stop spreading stupid gossip and leave your insecurities out of this forum. If you have anything against me, talk to me directly
