2006 IFR Certified Joe Schumacher Van’s RV-7. N123CX S/N #71486.
donmtt
Active Member
Patron
$179,500 or Best Offer.
This dialed-in RV7 is READY TO FLY. I’ve worked to take an impressive original build and made it IFR capable and dispatch ready.
Lycoming IO-360 B1B. Hartzell constant speed prop. Dual Dynon HDX 10" Touchscreens. Dual Dynon comms, Dynon Auto Pilot, Dynon Autopilot Control Panel, Dynon SV knob panel, ADSB in/out. GPWS and traffic. Backup ADSB and AHRS (on Foreflight) via Sentry. Seattle Avionics IFR charts on Dynon display.
IFR Certified Garmin GPS175 GPS.
Tinted slider canopy with Flyboys Supertracks canopy extension. New Fly LED's Landing, Nav, Taxi, Pulse lights. Electric trim/flaps, AP disconnect on stick. Rigged for smoke. Heated Pitot. Walnut Pilots Grip. Angle of Attack. USB Charging Ports. Dual Mags.
New in 2026: Goodyear tires. Michelin inner tubes. TSFlightlines brake lines. Halon fire extinguisher. GPS 175. Flyboys Supertracks canopy extension. New front main seal.
Last Condition check December, 2025
IFR Pitot Static check May, 2026.
All logs since new. Oil analysis since purchase. Always hangared. Approximately 1005 Hrs. No Damage!
Included but not (yet) installed: Monkworks generator. New brake pads. Oil filter opener. Miscellaneous tools, parts and wires for RV.
Nice plane. I’m not looking to buy, one is enough (Paul D obviously excepted), but if I were, I’d probably be reaching out. I didn’t see mention of an IFR navigator in the text, <SNIP>
Thanks. I added it.
