2000 hours
That is impressive since 2016. We did between June 2009 & June 2025 about 2400 Hobbs and approx 2100 Tach, so you have been hard at it :-)
Outstanding.
Also good to see that you're still trucking along at a good rate of knots... clearly the "slick" hasn't worn off in 2000 hours. :D
Outstanding.
Actually running a few knots slow - I am in the process of rebuilding/replacing the wheelpants due to years of use and abuse, and I'm currently running without the upper and lower gear leg transitions.
How many hours on auto gas??
Almost all of them - I have 68 gallons capacity in the wings, and I only buy 100LL when I'm on a long trip, and just enough to get me home with a comfortable margin. That might be 10% of my total time.
The first few years were on 91 premium with Ethanol, then the local stores here started selling 93 so I switched to that for a little more detonation margin. First 800 hours I was using the stock Bendix injection system with the Airflow Performance electric fuel pumps, then I installed the full SDS system.
