-2 hose fittings
TS Flightlines
Advertiser
As a point of information, some of you with early engines that were removed from certified planes, may have had -2 hose assemblies for fuel and oil pressure, as well as on some primer systems. The former solution was Mil 471-2D hose ends on 306 (H-5593) style rubber hose. Those that we have seen were very stiff--no snap, crackle, pop like Rice Krispies, but just snap and pop, broken during flexing.
WE make -2 stainless hose ends with certified nuts, stainless in this pic, for teflon hose. We also make an extended body version to custom bend angled fittings from 0* to 180*. This solves the issue of the rubber assembly, and teflon has no service life.
Same for the primer systems---same stem and body sized for the AN805-2 brass nut, ball seat connection. Set up for teflon. Custom creations!!
Tom
For those that don’t know, Tom makes top notch hoses with excellent customer service.
Bevan
RV7A
400 hrs with Tom’s custom hoses.
I had this exact issue, I ordered all new lines from Tom and figured this oil line was an an4. Called up Tom and he helped me out and made this -2 for me. It fits perfect and looks great. Thanks!
