I hope I posted this in the proper location.
I don’t want to start a controversy here. But I would like to know the basics of the different considerations regarding the choice of 2 blade and a 3 blade propeller.
I would like to keep it simple and keep it to fixed pitch.
What are the general advantages and disadvantages of each.
It would seem a three blade will almost certainly be more expensive given similar construction materials. Such as 2 blade catto and a 3 blade catto. And the 3 blade will weigh more than the 2 blade.
I also assume that the three blade will generally have a smaller overall diameter and thus give a bit more ground clearance.
But what about performance? can you compare 1:1 the same pitch?
Is one more quiet exterior noise than the other?
Maybe another way to ask is. Why would I choose a 2 blade over a 3 blade? (Or vice versa)?
