Finley,
I see you are onto it. I think the reason Lycoming are guarded with any data, and the reason they talk about 100 or any higher number is not that there is more power to be had, but it is due to the fact out of the factory their engines are not capable of getting all their 6 or 4 little engines playing the same game. TCM's generally do this better.
Having said that, I recently flew an identical factory IO540 powered RV10 and it went LOP with a spread no greater than 0.2GPH at various settings and went beyond 60LOP smotth as. That is the first time I have ever seen that. Ours was a pig out of the box, could not get all of them to peak without the spread being 1.5 or more GPH and it was clearly running on only a few cylinders by the time the last one peaked. We had to do a rough guess on the first two rounds of injector tuning just to get an engine we could work with to tune. Unreal.
So back to your comments yes the detonation margin. But this argument was about where best power is. The richer you go down around 200ROP the effective ignition is retarded and this is all about detonation margin. Get a well set up engine and you get best power from ALL cylinders at the 75-80 mark. However and here is the kicker..............Lycoming don't give you that when you hand over 30-50 AMU's.
So when you read their blurbs, and look at these generic graphs, they are butt covering IMHO.
So Dan, to your mental race..........
Is that at Cape Moreton you mean
So do we care about fuel burn for the trip? Is there a penalty applied for litres used over a certain amount? Or do we want to keep the engine for 2000 hrs? Just asking? Not sure what the Nascar boys get but a V8 Supercar engine is good for about 4000km (25k miles) and they play with mixture because fuel burn is a mission critical thing. Maybe Nascar do not care.
So I would have a well set up IO540, and being a race, it would be at a RPM figure in the 2600's (Pierre will know exactly what I am on about
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
) and I would run at a position probably just lean of full rich, Target EGT like for a climb, and I would go test all this on the Dyno first to work out where a good detonation margin might be. In the absence of good data it would be leaned just a fraction or most folk would say nahh just leave it full rich, waste some fuel so who cares. And this is why generic and simple statements are made for pilots not capable of understanding things for themselves.
Now, if there were fuel penalty points applied, and it was a real race, it would be over the start line as I had gotten the last one back from the peak side to the 75/80 point. Squeeze every equine unit per hydrocarbon I could.
Now lets take the race to 10,000' where the detonation issue is less a problem, or is not even a consideration. Where would you run now?
