alpinelakespilot2000
I just switched out my failed Plane Power for an new, but old school vans 35A 14814 alternator with a new 1975 ford/VR166-type external regulator. Wired with a B&C OV module per B&C/Aeroelectric schematics.
I'm showing 14.4V on my Dynon which equates to 14.7V on the main buss (my Dynon like most I've heard about reads low--about 0.3-0.4V in my case). The volt meter on my 696 confirms my buss is getting 14.7V. My fluke multimeter also confirms the 14.7 on the main buss. I know Odyssey batteries prefer higher voltage than traditional a/c batteries but this is quite a bit higher voltage than I got with my Plane Power (about 13.8V on the Dynon/14.1V actual on the buss) The upper limit of my green range was 14.6V, I think just because the Dynon came with that preset. I'm a bit worried that in flight I might occassinally see higher voltage and then have to wonder if I should abort a flight.
1. Should I be good with this voltage, especially given that it's feeding an a Odyssey? If so, at what higher voltage should I start to get concerned?
2. Should I find an adjustable voltage regulator so that I can adjust it downward? If so, any off the auto store shelf models you can point me too?
3. Should I be troubleshooting further? If so, any suggestions on where to start?
Thanks for any thoughts.
