0-540 Throttle and Mixture brackets
TrueAirSpeed
For those building RV-10s with a carburetor instead of fuel injection, what is your source for the throttle and mixture control bracket?
I know you don't want to hear this, but it's very much worth your while to go with fuel injection instead of a carb. The efficiency and control are wonderful. It's not that expensive and will pay for itself in efficiency.
540 carb throttle / mixture bracket
Hi Terry,
I see you are building a bearhawk - great choice to go with an RV! I am working on a BH 4 place and flying my RV4 I built.
What I did for bracket on carb 540 is start with the Vans bracket and did a bit of fabrication. A little cutting and welding but not bad.
Steve
rV4 completed
Bearhawk 4 place in process
Thanks Steve!
I have fabrication as an alternative, but thought I would look for off the shelf first. Thanks again and good luck.
