RV-3A N696DB - Inflight Breakup - June 15, 2026
I don't want to minimize this tragedy in any way, but it caught my eye that this is a RV3A...how many tricycle gear RV3's are out there? I guess I incorrectly assumed the answer was probably zero.
Hey folks - this is bad enough for the family that we don’t do speculation before the wreckage has cooled! Doug’s rules say that if a post even hints of speculating on a cause, it’s toast. At this stage, none of us knows anything except that the aircraft and pilot were lost.
Wow this is scary! Not sure how to handle this. I have been flying mine and have about 60 hrs on it and treating it in a very very gentle way. But I do wish there were people that know these RV 3’s that can do some inspections on them as most of the builders have moved on in one way or another. For the help of the other owners I hope we can get so honest history of this RV 3A.
Ugh, so young. It will be interesting to learn more about the failure in due time. Condolences to his family and friends, including the one flying with him.
There are plenty of resources to help you understand the construction of your RV3, its operating limits as well as inspection protocols. I suggest you start another thread to discuss that outside of this one.
Take comfort in knowing this is a rare incident. We will be waiting for answers.
RIP fellow aviator and condolences to family and friends.
Agreed. I think for the small few of us -3 drivers we need to have some sort of discussion about the way forward once the facts come to light. Incredibly tragic.
The way forward in the meantime is to "review and confirm" you're RV-3 has incorporated all of Van's wing spar, main and rear modifications.
We won't know till the final report and will take some time.
300 hrs on a purchased RV-3A
120 hrs on a completed RV-3B
mg
I personally have taken a great deal of care looking into my condition inspections and prior to purchasing. I think your idea to open a new forum separate from this tragedy. I hope that some of you highly respected builders can help with this so we new people can move forward.
mg
That’s a great question but how do you accomplish that? Does Van’s have records of if kits were purchased as a 3A vs a 3? Or if a 3 was purchased as a 3 but then the 3A spar kit was ordered to add on. I called and asked Van’s and was not able to find this out however this was a few years ago when they were in the middle of their issues. I did call and ask Van’s and was told that under the normal use category the wing had no issues.
You can message me if you like, don't what to go on here.
But I will say, I would pursue with Van's a description of all mods to the RV-3 wing spars
this was a must for me with the 3A.
Randy Lervold had a good history on his site, but long gone.
Someone may know where that can be found.
Without the mods, and built correct I believe is was considered in a Utility Category.
mg
My first RV build was an RV-3 started in 1988 and flew in 1992. The "RV-3A" was never an official designation by Van's Aircraft. The "A" referred to a design modification in the fuselage where it doubled the rear spar attach bars increasing the strength of the rear spar attachment.
The spars of the RV-3 and "RV-3A" were comprised of laminated bars riveted to the spar web. The current RV-3B (which is an official designation) wing has machined spar bars riveted to the spar web.
There were two RV-3 wing spar mods issued in the late 1990's that required deskinning of the wings to install.
in reference to the picture, I have a -3 with the "A" mod. This is not a result of the mod being added to the wing, when you look at the wing with the mod added, you can't see any evidence of it. The picture does not represent what the fuselage looks like on the -3 with the "A" mod added. Not speculating, just saying that mine does not look like that.
The “A” designation also included a modification/reinforcement of the inboard root rib of each wing.
If this is not the proper thread then perhaps Doug can create a new thread and move all relevant posts to it.
This isn't really the proper thread, and a new one was created this morning:
There is good information being talked about it, but please do it over there, as this just ALWAYS leads to speculation on a specific accident, and that’s not what Doug wants. We also don;t want to kill discussion….
Just to clarify what's needed to go from the RV-3 to the RV-3A, I posted this thread in the RV-3 section:
CN-1 and CN-2, Documents for the RV-3A​
Not speculation - I don't know anything about this accident airplane except that I sympathize with the pilot's family.
Dave
Sad day for friends, family and the community. I didn’t know the pilot, but after reading about him he appears to be an example of a smart, capable, young pilot who had a bright future ahead of him and was put in an unexpected and somewhat impossible situation.
RIP
Cole, the RV-3 pilot, was one of the good ones for sure. He truly had a passion for aviation, always asked the right questions, and was on track to do great things in this world. His impact on his students and everybody else around him will be felt for years to come.
Unfortunately, it was me in my RV-8 who Cole was flying in formation with that evening. It was a golden hour evening flight with perfect weather conditions, not a bump in the sky, and everything was flowing so smoothly. Almost like it was drawn up in a story book. It was a simple formation break, level at 2000’ and 140mph. Nothing more. No hot rodding, no hard G, nothing.. just low G break to the right. At about 45 degrees of bank and about 5 degrees nose up pitch, the right wing separated from the fuselage in the root rib area. Rotated almost perfectly 90 degrees vertical perpendicular to the fuselage. I couldn’t believe what I was seeing in the moment. The aircraft continued to roll to the right and fell out of view when I rolled left to de conflict with his aircraft. Never saw it again.
I only write this out for RV-3 owners and operators to know what happened.
I’m very sorry for your loss. Thank you for taking the time to write this.
Condolences for your loss, Nick, and sorry that you had to experience that. Sounds like a dreamy flight right up until the accident. Thank you for sharing and confirming this wasn’t a “pulled the wings off” kind of thing. Incredibly tragic all the same, and now we still wait to let the NTSB do their thing. RIP Cole.
Unfortunately, it was me in my RV-8 who Cole was flying in formation with that evening. It was a golden hour evening flight with perfect weather conditions, not a bump in the sky, and everything was flowing so smoothly. Almost like it was drawn up in a story book. It was a simple formation break, level at 2000’ and 140mph. Nothing more. No hot rodding, no hard G, nothing.. just low G break to the right. At about 60 degrees of bank and about 10 degrees nose up pitch, the right wing separated from the fuselage in the root rib area. I couldn’t believe what I was seeing in the moment. The aircraft continued to roll to the right and fell out of view when I rolled left to de conflict with his aircraft. Never saw it again.
>> Moderator Edit: Removed language alluding to a possible causal factor (speculative) in accordance with VAF posting rules.<<
This really hits home. What you said describes most flights I conduct with my friends, sometimes even in this specific area. I cannot imagine the feeling of being on top of the world in one moment and watching your buddy’s aircraft come apart and disappear. Deepest condolences for Cole and everyone involved. Very sorry for your experience and loss. 🙏🏼
I just heard about this. Tragic. This is a beneficial discussion of RV-3 structures. I am interested to read the final report. The Prelim and news reports are out. Been in the RV world since late 80's. Never built, owned an RV-3 but did fly one for about 5 hrs. Great flying plane.
Fun story, "Van" was at an Oshkosh many trips around the sun ago, doing Q&A after a presentation. He was asked what is your favorite RV, the RV-4 or the RV-6? He said RV-3. Got a good laugh. I was building a RV-6 at the time. Later models were not out yet.
