Does anyone have a Pre-flight Inspection List made?
Rik
The RV12 that I rent has a piece of paper that is double sided printed, the back side upside down so you have to flip the paper and search.
Well someone washed the plane and now a lot of the things are washed out looking and I was wanting to make one and have it laminated to eliminate this problem.
Anyone have a list already made out that I can get to avoid all the reading and copying?
Thanks!!
If you are renting an RV-12 I assume it is an S-LSA?
If it is, there is a POH for the airplane that is required equipment, that must be in the cockpit during flight.
That POH has an extensive (normal operations and emergency's) checklist inside.
Yes, there's a POH complete with 96 pages in a huge binder. However, I was wanting a preflight check list so that I can do the Cabin, Walk Around, Run Up, etc.. with something quick and handy. This way I don't have to fumble with the book to find something in case there is a need for something.
Thanks!
Thanks!
Are photo copiers against the law where you live? :D
Would that be The People's Republic of California?! -- Sorry, I'm a "Zonie" from Phoenix and couldn't resist!😈
Paper comes from trees
Yes they are legal, but being California, Kinko's will not copy any book/publication due to copyright laws.
Aren't the people in this state wonderful!:rolleyes:
Are they really just trying to save the few drops of H2O that would otherwise be used to grow the paper :p
No, they import the paper as it's a virtually illegal to cut down your own trees here without a public consensus of what you should do to make others happy. What's the term for that? Communism? :rolleyes:
