J Jrskygod Well Known Member Patron May 18, 2015 #1 What Dynon servos should I order for the 10? I've seen both the 42 and 52 recommended.
RV10inOz Well Known Member May 18, 2015 #2 You NEED the SV42T for the pitch, and a SV42 for roll. I do have the 52's but tuned down a bit.
Jesse Well Known Member Patron May 18, 2015 #3 RV10inOz said: You NEED the SV42T for the pitch, and a SV42 for roll. I do have the 52's but tuned down a bit. Click to expand... Exactly what I always install. No real need for the extra weight of the 52.
Janekom Well Known Member Patron May 19, 2015 #4 In my opinion you need the 42 with torque enhancer for pitch and a 52 for roll. We found that the 42 will kick out in turbulence.And also use the hole closest to the center on the 52.
