HeliCooper
A couple questions for you guys.
20-03 figure 2 has you flute the small tabs for the AHRS mounting bracket. Why are you fluting a flat piece of aluminum? Is it to create more of a pinch on the AHRS unit?
Is anyone installing a second AHRS unit and is there any reason I cannot just order the W-000012 parts and put them in the right wing? I think I can bend the flange on the W0012A 180 degrees to ensure the unit will sit flat. I don't know if that will put too much strain and weaken the aluminum too much.
What is the larger hole on the inboard side of the left bottom skin access hatch for?
Thanks as always
Thanks as always
