RFSchaller
I'm doing my annual and decided to balance the tires. I got the HF motorcycle wheel balancer with a set of weights using double sided tape to fix them. The main wheels went fine, but how do you guys who are doing this balance the nose Wheel? There doesn't seem to be enough surface to work with to attach the weights. Are you guys using the clip type? If you are where are you getting them?
