DonFromTX
I know this subject has been beat to death previously, I have read everything in the archives, but very little on solutions.
I cannot get my brakes to bleed, there becomes an air bubble in the tubing at the lower master cylinder connection. When fluid is pressured up from the wheel cylinder the bubble disappears into the master cylinder but never comes out the top of the cylinder no matter how much fluid you pump from below. When you stop, the bubble reappears! I have tried tapping the cylinder, pushing on the rudder pedals and such, with no luck. I also tried cracking the fitting to try to let the air out, no luck there either. It seems to defy physics, since the bubble of air SHOULD come out the top of the cylinder.
Others have had the same problem, since when bleeding it appears that the air is gone, only to reappear when you tap on the brake. The bubble is only 1/2 inch long, the pedal feels firm even with the trapped air.
After hours of work, I am totally frustrated with the system. Does anybody have some more ideas to try?
