Couldn't find a good answer so I'm going to ask.
The 24 g wires that go from the panel to the Kannad 406-AF (din 12 connector) are to large to "fit" inside the pins A, G & J of the connector. Am I suppose to use a smaller wire that will fit inside the connector pins to get a good solder joint? or do I peal away the existing wire strands in order to get a good snug fit? It looks like I'll have to remove a large number of strands. And, I don't really want to solder the wire on top of the pins.
john
john
