I'm looking for a better oil return port from the oil separator and found this. I would assume there is pressurized oil behind this port but sure would be nice to know if it could be used to drain oil back to the sump. It's the port right near the shadow of the oil line (to prop) in the photo. This is an O-360 right rear accessory case. The prop governor is just out of view to the left.
http://i59.tinypic.com/crg42.jpg
Bevan
Bevan
