Electrical Wiring Question?
Phantom30
I'm in the process of deciding which control grips to get.....I want at minimum to have push to talk, pitch trim adjust and auto-pilot disconnect on the grip(s).
Does anyone have a wiring schematic for this kind of set-up to tie into Van's factory wiring?
Now to figure out how to wire for pitch trim and auto-pilot interconnect.
Instructions should be included with the stick. Also, there will be a color coded chart showing what each wired is.
Here is a typical setup;
A/P disconnect is probably just a momentary connection to ground. Depends on which button you use, either yellow or gray wire, and white is grounded.
Pitch trim should be, red is power in, orange and black go to the servo power leads.
