NorthernRV4
I need some advice on planning out the rivet spacing on the Horizontal stab ribs, specifically where the mid and root ribs intersect with the forward spar channel. Both of these ribs have a joggle on the flange to allow it to fit inside the channel of the forward spar. In order to plan out my fluting locations I needed to lay out the rivet locations. Drawing 3a indicates 1.25" nominal spacing (can be closer but never further apart) but this places a rivet directly in this intersection area. It doesn't look like I can skip over this area without breaking the 1.25" rule and to put a rivet here will barely catch the area of the rib flange inside the spar channel and certainly not meet minimum edge distance of .25"
Mid Rib
RV-4 HS stab by jim_soutar, on Flickr
Untitled by jim_soutar, on Flickr
Root Rib
Should I simply remove more of the flange so that the rivet will only pass thru the skin and the spar channel?
Should I not put a rivet here at all and rely on the rivet line along the forward spar (skin attachment)?
Thanks all.
Mid Rib
Root Rib
Thanks all.
