Bill_H
Item A: I notice that my RV12 RPM "jumps around" a bit in increments of 10. Like 5000,5010,5020,5010,5020... Seems to be running very smooth. I figured this was an artifact of the Dynon sensing and display mechanism. But when I was going to get a prop balance, Walt A. was getting the same thing from the reflection-based readings of the prop itself - actually too much rpm variation to do the balance. Tried 4000 rpm (good throttle lock) and even WOT. No avail. Note: the prop balance was showing within limits, improvable, but rpm instability made the balancing process impractical.
Later I checked the plugs - all fine, 25 hrs since replacement. 75 hr TT on engine. "Mag" drop is good and even, "B" seems very slightly 'rougher' than the "A."
Walt thought it might be due to prop blade pitch differences. I was going to slightly repitch the prop anyway. So a couple of days later a check showed that the blades were still within 0.1 degree of each other, (so they were during the test) both before and after the repitch.
Do I have an ignition module problem? What to check? This engine has the soft start built in.
Item B: The prop test is done with the upper cowl off. I noticed about a 100rpm increase in WOT compared to my normal number with the cowl on. Also the idle with throttle full back was higher. Is induction significantly limited to the air filters by the cowl? (The idle phenomenon seems funny because it was originally set with the cowl off!) With the cowl back on, idle and static WOT readings returned to prior values.
Anyone else notice this? Would better induction to the air filters mean more power? Hood scoop anyone?
OH- I downloaded the Dynon data from after the test but haven't put it in Savvyanalysis.com yet.
