so many dimple dies
bobnoffs
hi all,
i have the recommended dimple dies from cleveland. asking questions about dimple dies i now find out there are fuel tank dimple dies and even substructure dimple dies. they set the dimple deeper for a layer of pro-seal and to accommodate layers of sheet metal. what are other builders using? are the extra dies [or only one or the other] helpful for building.
thanks
bob noffs
Nothing special needed.
hi all,
thanks
bob noffs
I don't believe any dimpling is done for rivets on the fuel tanks, and hence no specialized dimple dies needed there. Maybe its an issue on other RV designs, where flush/countersunk solid rivets are used on the wing-based tanks. The RV-12 tank just squishes two flat pieces of metal together with pulled rivets that have sealed ends.
You should not need the tank dies but you will need dies for a #6 screws which my set from Cleaveland didn't include.
