Every RV12 I've done has benefited significantly from balancing, if you haven't done this yet you need to!
(recommended by Rotax as well).
This one was a little bit of a challenge, took 5 runs to get it (could have stopped at run 4 but I like to see them less than .05 IPS).
Went from 0.544 IPS down to 0.019 IPS.
Owner said it appeared to need less throttle for the same RPM.
Hopefully JJ will post a picture of his plane with a fresh paint job, it looks awesome!
