Mike S
Senior Curmudgeon
My wife worked up a spreadsheet in Excel for the weight and balance for our RV 10.
It consists of two areas----first where you input the reading from the 3 scales, I.E. weight on each wheel.
It will then compute your total weight, moment, and C/G.
This is imported to a second area, where you input the fuel in gallons, the weight in each seat, and the baggage weight.
It will then give total weight, and C/G location for whatever configuration you have loaded into it.
It is also loaded onto my Palm PDA
I would be happy to share it with anyone who wants to play around with it.
This is set up for the RV 10, but you can change the moment figures for the various variables, and it should work just fine-------I hope. Check against known figures if you change things.
Send me your email, and I will send you the info.
Enjoy
Enjoy
