I started trying the balloon method, but with not much success. First attempt was with the skinny balloons that people make shapes out of, thinking their skinny neck would be easier to seal against the vent tube - but I just about burst my forehead trying to get those things inflated. I did manage to get a 'regular' balloon to inflate, but was unsatisfied with the quality of the seal I was getting. So after a little searching on the forum, decided to use the manometer method - easier, quicker, better! Thanks to those who went before. I did find two leaks - one around the schraeder valve, and one around the 'plugged' fuel outlet - put some grease on the fittings and that fixed that.
I'm going to let it sit for a day while watching the temp and barometric pressure. I also noticed during my searching that, in most tank pictures where I could tell, it looked like proseal had been dabbed around the shop heads of the baffle rivets and the heads of the pop rivets on the zee brackets. Probably a good idea, although I'll have to order my (gulp) fourth quart of proseal...
==dave==
Fuse kit ordered
==dave==
Fuse kit ordered
