Need a Little Help Please, Trivia Question
DonFromTX
I have got back on the wiring after a long vacation from it. I ran across this harness, no bag, no label, and cannot find it in the plans, but then again I don't have the engine drawings. Can anyone help identify it? It uses chrome plated shells.
[/IMG]
Problem Solved
Apparently it is a Dynon engine sensor cable - for an EMS or a D-180. Apparently I ordered it back when I did not know any better.
Wiring Harness Help
Look at the wiring schematic for the skyview EFIS and the EMS.
You should be able to match the wiring color/pin positions.
I am not sure about the DB9 connector colors but the EMS has to communicate with the EFIS.
Most communications are Blue and green and white with green and blue.
