Page 21-20 Block studs
redrv6
Hi All
I am having difficulty installing the 6 x MS21042-08 lock nuts on the block stud screws. Even with a helper holding the screw in place with a screwdriver under the belly skin, I can't tighten the nuts - they are so stiff. I've tried running the nut down the screw in a vice, but that required so much force that the screw bent.
What have others done here?
Shirley
Use some boelube on the threads of the screw. The length of the screw causes the nut to heatup from the friction of the locking action. The Boelube will allow you to get the nut all the way down without it heating up too much and binding on the screw.
Anti-sieze will work too
I squeezed the nuts a bit in a vice to make them a little less oblong (that oblong shape is the locking effect) and then gently ran a tap through them until they were a bit easier to turn. Put a dab of thread-locker on them as you tighten them up. The main thing is that it is a pain if they start turning when you later add the top pieces. -- David
Thanks for all the suggestions. The boelube worked fine - got the job done this morning. Another section completed - yay!!
Shirley
