Rainier Lamers
I have today released the full source code as well as free development tools including compiler for one of our older EFIS systems.
This is the monochrome Ultra HXL which is still an active product of ours and in regular production.
You will find a download link for an installation program on the Ultra page at www.MGLAvionics.co.za. This will install compiler and the Ultra HXL project ready to use. It requires Windows XP but will probably run OK on later versions.
The source code is released under the Free Software Foundations GPL license which grants you a lot of freedom but requires you to equally grant anybody else the same freedom for any changes or additions you make (i.e, you can't keep things for yourself).
You may use the source code and the compiler in any way you see fit, even create products in competition to ours (but with open source).
The Ultra HXL is in many ways an ideal testing ground for us to find out how open source could (or could not) work for an EFIS system and we are doing this as a test case. The project is relatively small and a reasonable programmer should be able to grasp the system and make changes fairly quickly.
One big thing though: This is released without a promise of any support by myself or MGL Avionics. I probably do not have the time to support your changes or find bugs in your code or figure out why something does not work.
This you must understand. You get all of this for free - but you are on your own.
Rainier
CEO MGL Avionics
Rainier
CEO MGL Avionics
