Page 32-11 Step 2 calls for attaching the rudder cables to the forward hole on the most inboard seat ribs. However Page 31-11 Step 7+8 say to attach the WH-F83 ground terminals to the same forward hole. How has everyone else dealt with this.Thanks,
Dan
Dan
I removed the screw that was holding the ground wires and replaced it with the bolt shown holding the Adel clamp. The bolt was long enough to hold the Adel clamp and the ground wires.
Thanks Dave,
I was unsure if I would do as you have or drill new holes. When I contacted tech support, all they said was (it is possible). Seemed strange to call out 2 different hardware apps for the same holes.
Dan
