And what do you call "slightly overheated" ?
Can you add some more information so we can give you a valid and well reasoned opinion?
1. What is the CHT normally in the cruise? 370
2. What were the CHT's at the time of this slight overheat? 425-450
3. What was the Manifold Pressure during the flight. 20in
4. What was the RPM used?2100
5. What was the Indicated Airspeed? 127kn...and is the plane fully finished i.e. all spats fairings etc fitted?yes
Cheers
DB![]()
Well ........maybe your friend might be interested to know.
But what is slightly overheated?
My CHT's usually run between 300-310 deg F, so for me 365 would be slightly overheated, but nothing to be concerned with if I was stooging around slow.
So what does slightly overheated mean to you and this particular aeroplane?
