Hi,
I have a slight leak from the inboard oil line connection to the oil tank. I believe it is a tapered connection.
On my installation the oil line fitting can be tightened right down to the neck on the oil tank. When I run the engine, oil weeps from this connection and collects on the rim of the tank, then overflows onto the battery box.
I have tightened the joint as much as I can but it still weeps. It seems to me that the two connections are preventing the taper from fully engaging. The only way I can see to fix this is to grind some material from the oil line fitting which seems a bit extreme.
Anyone any relevant experience, ideas?
First flight today with me in the driving seat - full throttle yielded 5520 rpm and 118 kts indicated - that's without spats. Cold outside though.
Thanks...Keith
Thanks...Keith
