I was going to add this to the "Crunch!" saga, but it's not easy to search for data on trim when you need to know that "crunch" is the keyword ;-)
The Light Aircraft Association in the UK are particularly interested in trim forces, especially in the runaway case. I eventually found the posting I was looking for. Larry conducted a test, posted 26th June 2010, in the Crunch string.
I repeated these tests yesterday, with a spring balance, as part of my UK flight testing.
I trimmed the aircraft straight and level at 60 knots with full flaps, then explored the out-of-trim forces at full up and full down trim settings.
I repeated the tests trimmed at 100 knots, with no flaps.
The pull, or push, required to maintain level flight at the trimmed speed ranged from 20 to 36 pounds. It is manageable with one hand (as Larry said), but I was surprised at quite how hard I had to push/pull.
At least now, if I ever got into a trim runaway condition, I have experienced the effort that is required to maintain control.
The LAA are interested in this scenario as there have been instances of problems with Sportcruisers fitted with autopilots. Apparently a wiring problem on stick-mounted trim buttons can result in a trim runaway. The autopilot tries to compensate until it finally trips out, at which point the aircraft violently pitches - apparently with sufficient force to risk structural damage.
Cheers...Keith
Cheers...Keith
