Epoxy/Flox Mix for wingtip ext.
Dave12
I am curious as to what the purpose of the epoxy flox mix. is on the wingtip extensions? Reinforcement? If the part fits well, must his still be done?
Tip Light Reinforcement
There is a space that has to be reinforced because you will be drilling and installing rivets through it. Otherwise the fiberglass will collapse and look pretty bad.
Here is a link to a good picture of the completed installation:
http://picasaweb.google.com/104592539075472798431/LightsInstalled#5546637208910887298
Tony
Proseal
I can understand the epoxy, but still have trouble understanding the purpose of the proseal under the lower flange of the extensions.
If the purpose is to seal the housing, then why not also seal the upper flange.
Anyway, I will still finish the installation as shown on the plans.
Rafael
RV8A flying
RV12 finishing wings.
