I really hate messing things up and even more so I hate advertising the fact to the world in questions like this. But I figure I'd rather swallow my pride and know in the end I've got a solid aircraft.
Firstly, apart from this question, I've finished my VS tonight and I feel really good about the job I did (aside from tonight's question) - thanks in great part to all those who have taken time to help me.
Here's my question. In riveting the bottom inspar rib to the rear spar, my hand drifted and the gun hit a few times at an angle before I realized it. I dented pretty good the bottom flange of the rib causing it to flare out as you get away from the head. Is it safe as is even though it looks pretty bad? Or should it be repaired/replaced? Please see pictures. By the way, the rivet itself set very nicely, though I don't have a picture of it.
Finished VS
View of the dented area. Directly around the head, the metal is snug against the spar. It only raises up from the spar as you get away from the head.
Second view. Looks bad to me but I don't want to jump through the necessary hoops of replacing this part unless it's an issue of safety.
View of the head from the top. From directly above, I think it looks OK. It probably hit 4 or 5 times at an angle before I realized. The metal is dented right at the edge of the head - but the head is not deformed.
Thank you,
Finished VS
Thank you,
