steve wyman
I mentioned reversing my throttle springs on the after flight mods thread, and I seem to have opened up a can of worms and I don't want the thread to drift from the original subject. In answer to you folks that object to my reversing the springs, you should also realize that I'll also be reversing the actuation direction at the same time. This means that when you push the throttle to full power, you are actually, physically pulling the throttles open ( the springs will, then, only aid in pulling the throttles back to idle). I used this same setup for 3 years on my RANS S-7, with no problems. In fact, RANS has you make this mod, in the build.
