Searching the forums I understand some folks have installed the rear seat crotch strap around the flap rod. Can someone tell/show me what method/hardware was used to attach it there?
I also have a Hooker seat belt in my -4, and added a rear crotch strap. As far as the attachment point for the crotch strap, you have to tie into the rear spar, and fabricate the attachment around the push rod that goes to the rear bellcrank, make sure you don't interfere with the movement of that push rod. Bring the attachment from both sides and terminate under the floor to which you would attach a triangular attachment (.125 aluminum or 063 -4130 steel). To that you attach your bottom crotch strap attachment.
