Help Need VS
spriteah
Hi fellow builders.
I hit a hurdle today. I am working on VS Page 06-05. Under step 3 it says Rivet VS-1208 and there are two parts being MS21051-L3 to be attached during the riveting.
When I line up the MS parts the 2 holes for a standard LP4-3 rivet on the sides (single tab) shown on drawing Figure 2 appear to be a long way out of alignment. I could flex them to line up but it does not look right.
Anyone remember this step and have a similar non alignment?
Jim.
To clarify the holes that do not seem to line up are the ones on the bottom of Fig 2 which state "Leave Open".
Jim.
Jim,
I agree that those holes do not line up correctly. The solution is to elongate the slot next to the tab about 1/16" using a 1/8" round file and deburr. Doing this will allow the tab to be bent to meet the hole without over stressing the sheet metal.
Joe
Great thanks for the info. Was thinking Im miss reading instructions. I will send vans an email.
Jim.
Hi fellow builders.
Jim.
Take a look at this page
http://www.joesrv12.com/Builder Log/bl_06_05.htm
