I am wondering if anyone who is done with their wings had the same problem I am having? After finishing up the ailerons and installing them, I found that the trailing edge of the right wing aileron is 3/8" short of the trailing edge of the fiberglass wing tip but the left wing aileron is flush with the tips trailing edge. After measuring things out, the fiberglass tip on the right wing is 3/8" longer than the left measured from the aft edge of the wing top skin, so the fiberglass tip is longer. I don't think it should be longer and the tips look like they came out of a mold. Before I shorten the right wing tip, I am just wondering if this is by design? My fix will be to trim the fiberglass tip to proper length, split the joint, prep the area and re-flox and finish. Am I missing anything here?????
