Canopy Frame ... Prime & Paint?
JerryG150
Is it OK to prime and paint the entire canopy frame? Are there parts of the frame that should be left bare metal so the fiberglass sticks? :confused: :confused:
:confused:Jerry:confused:
My suggestion
Hi Jerry, You can prime it all over. You may have to re-sand a few areas, but that is ok. I used a flat white primer, and flat clear coat. It is very easy that way, to touch up later when you get a scratch.
John Bender
Hi Jerry- The flat area, on the forward, out side of the frame, where the foam blocks are glued to, should be left unpainted, for the epoxy to bond to. Steve
