T Tweetr Well Known Member Nov 19, 2009 #1 I'm writing a weight and balance spreadsheet for a friend's RV-10. His photo-copied weight and balance sheet blurred the datum location. Anybody know the datum location for the RV-10? Thanks, Tom
Mel Legacy Member Mentor Nov 19, 2009 #3 The datum can be anywhere you want as long as you keep it consistent. I always use the leading edge of the wing.
T Tweetr Well Known Member Nov 19, 2009 #4 Auburntsts said: Here ya go: http://www.vansaircraft.com/pdf/RV10wb.pdf Click to expand... Thanks Todd! That's exactly what I needed. I know the datum can be anywhere; I was using someone else's numbers and needed the standard Van's location.
