Geico266
Just a warning to those guys getting their engine kits ready. Make sure you read the warning and literature on the proper procedures for starting a Rotax for the 1st time.
1. There is a specific procedure for pressurizing the oil reservoir so oil is forced back into the engine to purge air from the journals and passages. Failure to do this can result in major engine damage by air locking the oil flow. This is rare, but is can and has happened.
2. Make sure you know how to check the oil. There is a specific procedure for checking oil in a Rotax 912S. After the first start procedure, you'll need to remove the oil dip stick cap, turn the prop by hand until you hear a girggling sound, or check the oil after you run the engine. You cannot just check the oil like a Lycasoris.
3. We call it a "choke", but it is actually an "enrichment circuit". The choke will not work with the throttle open, only when it is closed. When the engine is running the choke does not work (very well anyway). It is a safety feature so you can't kill the engine with the choke in the air.
4. It is a real good idea to take a Rotax engine or maintenance course as soon as you can. These engines are great, run hard, dang near bullet proof, but they are different, and take a different set of skills and mind set to keep the working properly.
Have I forgotten anything?
I'm so pumped to get this bird in the air!
