N402RH
Now that I have all the fairings cleaned up and the plane is finally painted, I decided that it was time to compare its speed with another RV-10. My RV-10 has the Hartzell composite three-blade propeller and in previous comparisons with two other RV-10?s, it was a disappointing 7-9 knots slower. The two previous tests were done before my RV-10 was painted and the fairings had been cleaned up.
Yesterday, I had the opportunity to fly with Scott Gustafson's painted and very clean RV-10. Scott?s RV-10 has the standard Hartzell Scimitar propeller. We discovered that at 5500ft, 2500 RPM and full throttle, that both planes were going exactly the same speed.
I plan on comparing it with one of the previous RV-10?s later this week to verify the speed improvement. I have been thrilled with the composite propeller. It is extremely smooth and I really like that it can be easily repaired should it ever suffer any damage.
Upon landing, one of my neighbors walked over and proclaimed that it was time for him to show me how much faster his Bonanza F33A was. We took off in formation and climbed up to 5500ft. After flying south for around 10 minutes, we discovered that my RV-10 took around 2 inches less manifold pressure to keep up with his Bonanza (that was running full throttle). We then found that the RV-10 would go 10kts faster at full throttle.
My neighbors Bonanza F33A
Soon after landing, my OTHER neighbor showed up to discuss the results. He has a V35B Bonanza and everyone knows that the V-tail is faster. Ten minutes later we were taxing out in formation so that I could see how fast a real Bonanza was. We did discover that he was right, the V-tail is faster than the F33A and is only 7-8kts slower than the RV-10, and my plane had "all that gear stuff hanging out?.
Bonanza V35B, photo taking just before going to full throttle.
Rob Hickman
N402RH RV-10
