Mail to Sensenich 9th March:
As you know Vans Aircraft evaluated the ground-adjustable prop for their new RV-12 LSA aircraft. They elected to go with the fixed pitch prop. Was this decision based on price, or on weight? If on price, what would be the advantage to go with the ground-adjustable prop. I'm based in the UK so not bound by LSA rules in the USA.
Response 9th March:
Van?s has evaluated both the fixed pitch wooden propeller and the ground adjustable composite propeller on the RV-12.
While they were intending to only offer the wood prop for the RV-12, I believe they have now selected the composite propeller as the standard propeller.
Initially they had a concern about the pitch range of the adjustable prop, thus allowing to the propeller to be set too high or too low and thus compromise climb performance. But we?ve addressed this with a special pitch stop ring which will only allow climb, standard, and cruise pitch on the RV-12.
I don?t know if they will have both the composite and wood prop on the standard equipment list.
For right now, I believe the composite adjustable prop is the standard.
My comment:
They have a good short video on their website showing how to adjust the composite prop - don't know if this is for the RV-12 prop, or the one for the Lycomings, or indeed if it is a variant of the same prop.
Cheers...Keith
Response 9th March:
My comment:
Cheers...Keith
