Don't Use Blue Marker On Powder Coat!
Geico266
I was assembling the rudder peddles following the directions like a good little builder and marked the parts as described in the plans. During final assembly I took some adhesive remover and it would not touch the blue color. I then took acetone and it took the shiney finish off the powder coat! :mad::mad::mad:
Some days are diamonds, some days are coal. ;)
I had the same problem with a painted surface. Ended up using
Fritz. The same stuff for polishing aluminum. Put it on, let it set, than wipe it off.
A bit of polish will shine the powder coat right up.
WD-40
Many times I have found that WD-40 will take off 'whatever', and it will not take off the finish. Try it. Doesn't seem to hurt the painted surface.
John Bender
Yes, rubbing alcohol. Cheap, easily obtained, effective & safe. It also evaporates completely, leaving no residue.
If you use WD-40, paint won't later stick to it so you need to be sure you don't get overspray on anything you might want to paint.
What to do with WD-40
WD-40
A man had bought a new pickup. His neighbor got up very early one Sunday morning and saw that someone had spray painted red all around the sides of this beige truck (for some unknown reason). The neighbor went over, woke the man up, and told him the bad news. He was very upset and was trying to figure out what to do. Probably nothing until Monday morning, since nothing was open. Another neighbor came out and told him to get his WD-40 and clean it off. It removed the unwanted paint beautifully and did not harm his paint job that was on the truck. Here's the scoop for those looking for a "solution" to other problems.
Water Displacement #40. The product began from a search for a rust preventative solvent and degreaser to protect missile parts. WD-40 was created in 1953 by three technicians at the San Diego Rocket Chemical Company. Its name comes from the project that was to find a 'water displacement' compound. They were successful with the fortieth formulation, thus WD-40. The Corvair Company bought it in bulk to protect their atlas missile parts.
Ken East (one of the original founders) says there is nothing in WD-40 that would hurt you...' IT IS MADE FROM FISH OIL!' When you read the 'shower door' part, try it. It's the first thing that has ever cleaned that spotty shower door. If yours is plastic, it works just as well as glass. It is a miracle! Then try it on your stovetop... It is now shinier than it has ever been before.
1) Protects silver from tarnishing.
2) Removes road tar and grime from cars.
3) Cleans and lubricates guitar strings.
4) Gives floors that `just-waxed` sheen without making them slippery.
5) Keeps flies off cows.
6) Restores and cleans chalkboards.
7) Removes lipstick stains.
8) Loosens stubborn zippers.
9) Untangles jewellery chains.
10) Removes stains from stainless steel sinks.
11) Removes dirt and grime from the barbecue grill.
12) Keeps ceramic/terra cotta garden pots from oxidizing.
13) Removes tomato stains from clothing.
14) Keeps glass shower doors free of water spots.
15) Camouflages scratches in ceramic and marble floors.
16) Keeps scissors working smoothly.
17) Lubricates noisy door hinges on vehicles and doors in homes.
18) It removes black scuff marks from the kitchen floor! Open some windows if you have a lot of marks.
19) Bug guts will eat away the finish on your car. Removed quickly, with WD-40.
20) Gives a children's play gym slide a shine for a super fast slide.
21) Lubricates gear shift on lawn mowers.
22) Rids kids rocking chairs and swings of squeaky noises.
23) Lubricates tracks in sticking home windows and makes them easier to open.
24) Spraying an umbrella stem makes it easier to open and close.
25) Restores and cleans padded leather dashboards in vehicles, as well as vinyl bumpers.
26) Restores and cleans roof racks on vehicles.
27) Lubricates and stops squeaks in electric fans.
28) Lubricates wheel sprockets on tricycles, wagons, and bicycles for easy handling.
29) Lubricates fan belts on washers and dryers and keeps them running smoothly.
30) Keeps rust from forming on saws and saw blades, and other tools.
31) Removes splattered grease on stove.
32) Keeps bathroom mirror from fogging.
33) Lubricates prosthetic limbs.
34) Keeps pigeons off the balcony (they hate the smell).
35) Removes all traces of duct tape.
36) Folks even spray it on their arms, hands, and knees to relieve arthritis pain.
37) Florida's favorite use: 'Cleans and removes love bugs from grills and bumpers.'
38) Protects the Statue of Liberty from the elements.
39) WD-40 attracts fish. Spray a LITTLE on live bait or lures and you will be catching the big one in no time.
40) Fire ant bites. It takes the sting away immediately and stops the itch.
41) WD-40 is great for removing crayon from walls. Spray on the mark and wipe with a clean rag.
42) If you've washed and dried a tube of lipstick with a load of laundry, saturate the lipstick spots with WD-40 and re-wash. Presto! Lipstick is gone!
43) If you spray WD-40 on the distributor cap, it will displace the moisture and allow the car to start.
Keep a can of WD-40 in the kitchen cabinet over the stove. It is good for oven burns or any other type of burn. It takes the burned feeling away and heals with NO scarring.
Remember, the basic ingredient is FISH OIL
Before you use it in the Kitchen or around the BBQ, keep in mind that WD-40 is flammable. I used it as a propellant in my potato launcher, although hair spray works better.
Say WHAT ?
OK, I'll bite (no pun intended): What's a Potato Launcher? :confused: I, obviously erroneously, thought that potatoes were for, you know, like ............ eating! :)
Oh!........ you have lead a sheltered life! No childhood is complete without launching a spud half way across the neighborhood.
http://www.instructables.com/id/The-Original-Potato-Cannon/
This is how the Irish won wars!
I wonder if a wing mount version is available.
