Denny Myrick
When I attached the wing tip close-out (Page 17-06) I was surprised to see how much the bottoms of the V-shaped notches showed around the perimeter of the wing tip close-out where the bent tabs are located. I noticed Jim Cone's build picture (http://picasaweb.google.com/JimCone1941, 4-29-08, photo 4) shows the same thing (especially if you enlarge the photo) but not quite as bad as mine. I encountered the same problem (but to a lesser extent) when attaching the Forward Wing Tip Rib (Step 5, Page 17-05). I talked to Van's Ken Scott who looked at the company's RV-12 and said their Forward Wing Tip Rib looked similar. Anybody else encounter this problem with the bottom of the V-Shaped notches showing? More importantly, as I complete my second wing, is there any way to avoid this?
Denny Myrick
Denny Myrick
