FS: (Price Reduced) AFS AoA Pro angle-of-attack system
Thermos
Friend
Hi all -
I just just removed this Advanced AoA Pro system from my RV-7, it worked fine as of its last fight in the airplane in December 2025. It's pre-calibrated for RV-4/6/7/8/10, but can be re-calibrated to other aircraft. The blue tape on the computer is covering the hole I drilled (per instructions) to allow access to the voice alert volume pot.
Priced reduced - $300 plus shipping. PM me for contact info if desired.
Dave
I am interested in the AOA if I can get it to work on a RV9A wing. Will you give me a text at five four one 913 zero six one zero and we can talk about it
Hi -
Yes, it will definitely work on an RV-9 wing. I installed the pressure ports at predefined locations on my RV-7 wing, and I’m reasonably sure that Advanced could provide you with similar definitions for the -9 wing.
Can I ask where you’re located?
Dave
I could be interested in this for my 4 if it's something that can be retrofitted to an existing wing and Dux doesn't buy it from you.
Hi,
Yes, it can be integrated into an existing RV wing. The wing pressure ports are installed in the most outboard wing bay. You’ll need to be able to run pressure tubing through the wing to the cockpit.
Dave
